CMU or Concrete Stem RW Design
I have a spreadsheet that can now only do cantilever retaining wall. I would like to add option for CMU stem or combination of concrete and cmu stems (up to 3 sections). I also want to add an option for top restraint. What references would give the equations and theory I need? Thank you.
RE: CMU or Concrete Stem RW Design
For a top restraint - I'm currently looking for a good reference as well however I know that the "Basics of retaining walls" by Hugh Brooks discuses this some. Usually an assumption is made that the top and bottom are pin-pin or pin-fix. If the bottom is fixed than the footing would need to be designed for the moment (bearing pressure check as well). Usually I check to see if passive pressure or a concrete slab will act as a 'pin' condition at the bottom of the stem.
EIT
www.HowToEngineer.com
