Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your site is a great idea. I should have joined your site years ago. Better late than never..."
Geography
jas2000s (Chemical)
9 Jul 12 15:17
I am trying to size an overflow pipe line for Atmospheric tank. I know I can not size it based on inlet flowrate.
I need a good explanation why overflow pipes can not be sized based on inlet flowrate. The overflow discharges to ground. Some one was arguing to use the vent as an overflow to mimimize the cost, but you can not use the vent as an overflow. I am confused.
GHartmann (Chemical)
9 Jul 12 20:15
There is no reason not to size the overflow on the basis of the inlet flow. Maximum outflow (overflow) has to equal maximum inflow. The only restriction is the lower pressure drop needed in the overflow line.
Good luck.
TD2K (Chemical)
10 Jul 12 1:36
I agree with GHartman. What is the purpose of the overflow line? It's to prevent your tank from overfilling which means to me that the line has to have a capacity equal to the inflow.
MJCronin (Mechanical)
10 Jul 12 9:25
This topic has been discussed before in other fora
http://www.eng-tips.com/viewthread.cfm?qid=214602.
Even the slowest among us should recognize that pumped flow INTO the tank follows different rules than self venting gravity flow OUT FROM the tank overflow
(Hint: the Froude number is the key !)
It is not clear to me what "sized based on inlet flowrate" means in the original post.
Do you mean that the overflow and inlet pipe line size must be the same ?
(You may want to consider posing your question in the STORAGE TANK forum)
Close Box
Join Eng-Tips® Today!
Join Us             Close
