Buckling of shells, Nonlinear analysis
I'm working on the buckling of cylindrical shells subjected to axial loading. In my case the cylinder is resting on 4 columns, so there is a possibility of local buckling above the support. I'm carrying out the non linear analysis in abaqus using riks procedure.
The problem is when I plot the LPF vs displacement (radial displacement of a node in the buckle region) I notice some regions of abrupt variations and overlaps in the curve, which is not expected. I have attached a snapshot of that. can anyone suggest me the possible reasons for that?
RE: Buckling of shells, Nonlinear analysis
BA
