Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I am very happy with the whole site and would like to extend my compliments to all of you who work to make it one of the most useful sites (If not THE Most Useful) ...and the easiest to navigate..."
Geography
mcgyvr (Mechanical)
9 Jul 12 14:58
Having a problem here..
I'm using the attached circuit to measure -75 to 75V and output it to 0-5V for sampling by a micro (2.5V -/+2.5V).
Except instead of the 2.5V voltage as shown in the image I'm using a LM4128 2.5V series voltage reference. (personally never used a voltage reference chip before)
Reading negative voltages works just fine and the output of the LM4128 stays stable at 2.5V. (Vout goes from roughly 0V to 2.5V as Vmeasured goes from -75 to 0V as I want)
The problem is measuring positive voltages.. At about 10V into Vmeasure I'm getting 4.5V or so at the output of the LM4128 causing the circuit to not work properly. (basically as Vmeasure is going up positive Vref is also going up)
??help
Here are the voltages I'm measuring at Vout (don't have the micro attached yet..All measurements made with a fluke multimeter)
Vmeasured----Vout
Negative input voltages
0V=2.5V
-10V=2.17V
-20V=1.84V
-30V=1.51V
-40V=1.19V
-50V=0.86V
-60V=0.53V
(basically .33V per 10V) OK..Seems to work fine..
NOW..
Positive input voltages
0V=2.5V
5V=2.75V
6V=3.18V
7V=3.64V
8V=4.02V
9V=4.57V
10V=4.57V (stops here and won't go any higher)
If I replace the LM4128 with a 2.5V power supply all works just fine.
x7r (Structural)
9 Jul 12 17:46
I've never used this IC, but its datasheet implies that it is designed to work as a voltage source -- but not necessarily a load. So it supplies the intended load current polarity when your measured voltage is negative, but not when your measurement is positive.
x7r (Structural)
9 Jul 12 17:57
Assuming my first answer is correct, I think a solution would be to add a resistor from the output of the LM4128 to a positive supply voltage (+12V, for example). The resistor value would be selected so that it drew roughly 2 mA of current from the regulator. Therefore the resistor value would be roughly 5kohm. That would keep the overall output current from the regulator positive.
Helpful Member!  x7r (Structural)
9 Jul 12 18:29
Sorry -- I answered a phone call while I was typing the previous answer, and didn't immediately notice my mistake. I should have said that you can use a 5 kohm resistor to a negative supply, or possibly a 1 kohm resistor to ground.
Helpful Member!  IRstuff (Aerospace)
9 Jul 12 19:43
A typical voltage reference cannot be used as a current sink. They are only designed for sourcing.
TTFN
mcgyvr (Mechanical)
10 Jul 12 8:53
Thanks..
Off to find one that can source/sink. I wasn't aware of that limitation with voltage references.. Assumed they were just more stable/lower current voltage regulators.
VE1BLL (Military)
10 Jul 12 9:26
As hinted by xr7, you could possible add a load resistor to ensure that there's always a sink.
mcgyvr (Mechanical)
10 Jul 12 9:48
xr7/ve1bill,
Simply adding a 1k resistor from the output of the LM4128 to ground solved the problem... Perfect..
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
