Now everyone can build a satellite like NASA
"Stress relief"... for potential satellite designers....
If you've ever wondered what it would be like to build a satellite to peer into a black hole and uncover its secrets, now you can find out thanks to a free new online game from NASA.
The new game, called "Build It Yourself: Satellite!" was launched from the NASA Goddard Space Flight Center in Greenbelt, Md., and is a learning tool for students and adults.
"It's fun to play and users will learn something about satellite instrumentation and optics, and how they are used to make scientific discoveries, as well about a large range of different existing astronomical missions," said Maggie Masetti, NASA webmaster who authored and created the game at NASA's Goddard Space Flight Center in Greenbelt, Md. The game has players choose what science their satellite will study, and then decide what wavelengths, instruments, and optics will help them to learn the most about the science they chose. After "launch," the player will see what their satellite looks like, and learn what real mission has data similar to what their new satellite might produce. A large range of astronomical missions, dating from the 1980s to today are represented, from small X-ray telescopes like NASA’s Rossi X-ray Timing Explorer, to the large NASA/ESA Hubble Space Telescope, and beyond.
Make your game choices carefully and you could build a satellite very similar to NASA's next-generation James Webb Space Telescope, the original inspiration for this game. (The game is located on its website.) The cutting-edge Webb telescope is being built right now and will launch in 2018. It will help scientists see the secrets of the universe farther back in time toward the Big Bang by using infrared-vision. The Webb has a tennis-court sized sunshield, and a large segmented mirror that will make it the most powerful telescope ever built by NASA.
This game requires having FLASH 9 or higher on a computer. It opens in a separate window or tab and requires a few seconds to load all of the graphics components.
The game comes in two sizes, dependent upon the size of the user's monitor. For those with a slower computer, there is a special toggle button that will reduce the quality of the graphics and make the game run more quickly. The artwork in the game is by Susan Lin, and it was programmed by Kent deVillafranca.
"Build It Yourself: Satellite" gives everyone a chance to be an engineer and an astronomer by learning about the different instruments that can go on different kinds of space-observing satellites, and seeing what kind of cosmic discoveries they might make. Hopefully it will inspire someone to become a real engineer or a space scientist.
Image caption — When you successfully build a satellite, the game will show you what it looks like and what kind of data it might produce. Courtesy of NASA, M.Masetti.
To build your own satellite, visit: www.jwst.nasa.gov/build.html.
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
RE: Now everyone can build a satellite like NASA
Is this a satellite that will cost about 8 gigabillion dollars and take 20 years to build?? Or something that SpaceX or Rutan can put together in a few years at 1/20th the cost?? And whose safety record is 100% up till now..
And NO I am not a left winger nut case - I LOVE the space program and have watched it since I was about 8 years old. (I am now 60) Other than the mid 1960's - what took so long and cost so much money??
Mike...
So far SpaceX and Rutan et-all have built launch vehicles... and are just now getting into payloads [satellites, manned spacecraft, etc].
Note. Although NASA, USAF and the USN [and to a minor extent the USA] have have somewhat cumbersome space programs, they have been successful in absolutely unknown areas of research and exploration. Lessons learned the hard way... and well documented... are situations avoided by the start-ups.
NOTE. China is a classic example of learning from everyone else [Ruski's]... and/or stealing what they can't learn otherwise. Easy to be successful when plowing ground that was plowed 40--50+ years ago.
Regards, Wil Taylor
Trust - But Verify!
WK -
Can't really disagree - but like I said - other than the 1960s' NASA has not shown me much!!
