Adhesive Contact
Adhesive Contact
Adhesive Contact
I am doing a FEA on the plastic casing by applying force normal to particular area. However, I have a PMMA screen bonded to the plastic casing by adhesive layer. How should I get this input into FEA? I had tried to put "bond" contact between both contacting surfaces of two components. But the result does not meet expectation, as I have done physical testing on real parts. I would like to do FEA to validate the existing design before I do modification.
Thank you.
Loke
RE: Adhesive Contact
Have you tried modelling it as a composite?
Do you mean modeling the Adhesive layer (let says 0.5mm thickness) in between the two parts and set it as a composite material? What about the contact settings? Set Bonded or no penetration?
Thanks.
Loke
What is the purpose of the simulation? Is it to model the strength of the bond or is the bond simply to transfer load to a different region of interest. If it is the latter I would model the part as 1 solid with different material properties. I hope this helps.
Rob Stupplebeen
https://sites.google.com/site/robertkstupplebeen/
