shear moment interaction curves
hey,
Does anyone know if it is possible to get shear moment interaction curves using SAP2000 V14.2 advanced.
I am modeling a steel frame with perforated beam, and i need to check its seismic behavior.
if the curves can be generated using the program it will helped a lot.
thank you very much :)
