Building simple Macro help
I have never written any computer code, if someone could help me with a simple macro. Our eng. department summarizes data from one work sheet to another. What I would like to be able to do is take the test data from one sheet and summarize it to another. The test data doesn’t always come off the same way so I think it would work best if the Macro looked for a word in a row and then located the correct Colum and then collect the data. Please picture below example in an excell grid format
Barometer 29.19 29.19 29.19 29.18 29.18 29.17 29.17 29.18 AVERAGE
Apple 103.9 104. 104. 104. 104.1 103.8 103.9 103.97
Orange 74.04 73.99 73.95 73.97 74.04 74. 74.04 73.99
It needs to find "Apple" then count over however far to the Average column and pull the data and then paste it into the new summary sheet. If someone can get me started I will work on completing it.
RE: Building simple Macro help
1. Paste the following into an Excel spreadsheet cell:
CODE
=VLOOKUP("Apple", A1:J3, 10)2. For more assistance, try the engineering spreadsheets forum (link below). Be warned though, some folk might expect that you've done a little more work on your own behalf before asking for help!
http://www.eng-tips.com/threadminder.cfm?pid=770
CODE --> =VLOOKUP("Apple",A1:J3,COUNTA(A5:J5))
This will give you the last value in each row, no matter how many columns there are... the caveat is that the average column would need to be in the same column for all data sets.
