Pls can any tell me the were i can
Pls can any tell me the were i can download software on materials selection.
RE: Pls can any tell me the were i can
Material selection for what application???????
Metals,ceramics,cermets ,plastics, electronic materials ,please be more complete. Once you have decided,go to ASM website and select appropriate volume and download (after you pay their subscription).
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
Here are two starting points for corrosion resistant alloys. For carbon steel you while have used the desired properties and work backwards to find a suitable alloy. If either requires any code or standard for you project this will require that you get the apporate set stands.
http://www.ssina.com/index2.html
http;/ nickel development institute.com
