Compressible Fluid Maximum Velocity
Hi Everybody,
What is the maximum permissible(allowable) velocity of compressible fluids for peroidic services such as relief valves vent stacks?
Reguards
Reguards
RE: Compressible Fluid Maximum Velocity
Good luck,
Latexman
inside the relief valve it is often sonic, while you want to avoid sonic conditions in the discharge piping
Would you please inform me from some practical range?
Regaurds
Others have stated their company policies here. As TD2K suggested, use Search (between Forum and FAQs). It's pretty slick.
Good luck,
Latexman
