SUPPLIER OF FDA APPROVED METERING PUMP
I NEED YOUR HELP IN IDENTIFYING SUPPLIERS FOR METERING PUMPS WHICH ARE FDA APPROVED FOR FOOD PROCESSING.
APPROXIMATE DELIVERY OF 1qt PER 5sec.
FLUID HAS LOW VISCOUSITY.
RE: SUPPLIER OF FDA APPROVED METERING PUMP
I suggest you check with Neptune pumps at (www.neptune1.com)
and Milton Roy (LMI),at least they will direct you to FDA approved manufacturers.
A beautiful site is (www.askache.com),where you find itemised equipment suppliers.
Goodluck
Whylie
The specific type acceptable will have to be up to you and the inspector that will approve it's use in your plant. Manufacturers include Bran+Luebbe at www.branluebbe.com, Moyno at www.moyno.com and Waukesha at www.gowcb.com.
American Lewa introduced sanitary and hygenic diaphragm metering pumps earlier this year. These are spin-offs of their Ecodos line.
I don't want to be accused of promoting any products, so if you want my opinions about these pumps, let me know. I've only used the standard Ecodos pumps.
Scott
SIEGFRIED HEGER
SIEGFRIED HEGER
