ETAP - Resolution of tcc text
The attached file shows a tcc I have exported from ETAP to Word.
The ETAP Help Desk has informed that the text resolution on the attached tcc can not be improved.
Can any ETAP user suggest how the tcc resolution can be improved ?
Increasing the font size is not a preferred solution.
RE: ETAP - Resolution of tcc text
Is this resolution significantly worse than if you print it directly from ETAP or print as a .pdf? If you print as a .pdf with pdf995 or similar, you can crank up the dpi in the resolution.
(My EasyPower TCCs look great in Word
The resolution is fine when I print directly from ETAP or print to a pdf file, however I have had to create "dummy" fuses to represent vertical and horizontal lines of the Gemstart 4/5 contactor protection function which does not exist in the ETAP library. These dummy fuses appear in the tcc when I print to pdf. To exclude the dummy fuses, I slide them out of the tcc and use the Microsoft Snipping Tool to copy and paste to a Word document.
My PTW tcc's also look great in Word.
