Elastic plate buckling coefficient for plate under pure bending
Good evening,
I am trying to find an expression for the elastic plate buckling coefficient for a plate under pure bending. I would think the expression would be in terms of the width and height, but all I can find are specific values for fixed and pinned boundary conditions. Is this because it is empirical and closed form solutions are nonexistent?
RE: Elastic plate buckling coefficient for plate under pure bending
What are the proposed dimensions for this "plate"? How is it mounted - what are the boundary conditions - and where is the load loads?) and moments going to be applied and from what directions?
Will it act as a thin, skinny, vertical column threatened by buckling? A squat square column threatened by fracture/compression?
BA
Will include also later some worksheets for the practical application of same in Mathcad 2000 Professional.
I think the table (or similar tables) explaining the cases are also in Galambos IV or V in which case I may also have worksheets in english about the buckling of panels subject to longitudinal stresses, that I may post later.
Refer to the guide for stability of metallic structures in such edition for the info.
I think I completed also the port of the issue as per Ziemian's latest guide of 2010 (I stopped the work after chapter 5 somewhat into the 6th), will post the worksheets later if such is the case.
