available length of reinforcement
Branch connections to ASME B31.3
In section 304.3.3 the length of branch available for reinforcement (L4) is determined from two formulae and the lesser of the two is used.
In my problem, this value is 1000mm.
However, if there is a flanged connection only 500mm along the length of the branch, is it necessary to limit L4 to 500mm, or is this being very conservative?
Also, does it make a difference if the flange is a connection to an isolation valve?
RE: available length of reinforcement
However your figure of L4=1000 mm is really surprising: what kind of a huge thing are you speaking about?
prex
http://www.xcalcs.com
Online tools for structural design
L4 is actually very short.
d2 is the length I was using which is NOT along the length
of the branch but along the length of the pipe itself.
Hence the flange on the branch is irrelelvant.
Thanks Prex, as I thought, you can't take the compensation from the flange.
Cheers..problem solved
