Management Structure & the Personnel Manual
Greetings,
I'm a Mechanical Engineer working for a small "Recreational Vehicle" manufacturer. We've got about 15 full-time employees and sell about 40-50 vehicles a year. Everything we build is make to order. We've been "in development" from about the early 70's up until the early 2000's. Our product has been developed & stabilized and the business is ready for expansion.
However, up to now we've been operating as a fabrication shop. We carry a heavy "fab shop" mentality thats more reminiscent of a retirement home than a manufacturing firm. -- Largely this is the fault of management, or the lack there-of.
Among other things, I've been trying to transform the company to a manufacturing mentality and away from fab-shop/retirement home state. One of the biggest problems is our complete lack of leadership. The management structure here is almost completely flat. There is the owner/president and then there is everyone else. Such a flat structure prevents the development of "teamwork" and does a great deal of damage to moral. It also prevents any real strategy from being implemented. In part, this is because the owner leaves much to be desired in terms of "people skills" and openly admits these faults.
There are 2 assumed managers in the factory (1 for assembly/fab & 1 for composites) but their roles are blurry and informal. We created a "chain of command" diagram several years ago but it was never followed. Now, after working with the owner, I've been tasked to do whats necessary to get things in shape. One of the first things I intend to do is reenact this "chain of command" and get it working. The owner has agreed to follow any such "structure" but will take some work to get it fully implemented. One of the pros of such "chain" is the reduction of people dealing with the owner, which will be limited to just a few managers. It then becomes much easier to foster a positive owner/manager relationship when only dealing with a few individuals. It also will act as a "check valve" to prevent the "poor people-skills" from flooding the factory & drowning moral.
My question is how should I "document" the Chain-of-command policy? The most significant change is its effect on communication, as now the "president" will be working only with a few upper managers instead of every individual employee. Those managers will then be responsible for implementing & maintaining whatever policies/strategies we decide to implement next.
So I figure the best way to start it is with a revision to the personnel manual(which would be more symbolic than anything), followed by individual employee reviews (which are due anyway) in which we can briefly discuss the changes & their role in it.
I've looked everywhere and I have yet to find a good example of a "management structure" being described in an employee handbook/personnel manual. Does anyone have any good examples? Otherwise, how does a company document the operation of its management structure and/or its communication chain?
VS
VS
RE: Management Structure & the Personnel Manual
As far as an example, I have seen it best laid out with a pictorial "tree" type format. Less description and more of a visual representation of who reports to who. This was inserted directly into the manual.
I am not sure if this is what you meant by example or not but I personally found it very helpful to see it in this way.
Your strategy of putting it out there and then conducting reviews or individual meetings to make sure everyone is on the same page is the right approach I think. You may want to offer the initial roll out in 2 phases though. First, put your idea/structure together and pitch it but then allow the review meetings to be a chance for individuals to chime in and offer suggestions on making the structure work more efficiently...(for instance, maybe employee A currently deals directly with manager B because its very efficient to do so and the implementation of a system that doesn't allow this would hinder efficiency). Also, by giving employees a chance to put their thoughts into it before the final roll out, it will help to ensure they "buy into" the new program and therefore may be more likely to go along with it instead of maintaining the status quo.
Not sure if this is the help you were looking for or not but good luck!
PE, SE
Eastern United States
"If a builder builds a house for someone, and does not construct it properly, and the house which he built falls in and kills its owner, then that builder shall be put to death!"
~Code of Hammurabi
Good luck!
Boottmills
If you are in a power struggle with someone else, well that is not unusual, but it sounds like you are trying to run a prison camp rather than a factory.
Is the manager backing you up on this? You have no chance of success whatsover unless he does.
JHG
Regardless, I think you have just wandered into a swamp of unimaginable depth and breadth. It's sort of like a Florida mudhole. (*)
* Ed Hertfelder, one of my favorite writers, used to write for "Dirt Bike", and ride "enduros", which are sort of like a TSD rally, minus the pavement and minus two wheels. In a place like the New Jersey Pine Barrens, the assigned routes often go through mudholes, where most riders get stuck, fall off, and otherwise clog up the works, and the winning riders enter the mudhole, zip through it, and ride out the other side. Ed said it took him a few Florida enduros to realize that in a Florida mudhole, there is no other side.
Mike Halloran
Pembroke Pines, FL, USA
What role has he employed you in. Are you sure you actually heard what he said as opposed to what you wanted to hear.
He has been in business a long time and presumably makes enough to pay the bills. How long have you been there and have you previously run a business with a better record of success than this one. If he once made good money, but it has declined to the point where viability is now an issue, maybe real change is in order, otherwise, if it ain't broke, don't fix it.
If the owner truly wants the business to get into production, maybe the best idea is to split into two departments at least with regards to management. One to make the established design and another to continue with custom fab and development so your production model is not an obsolete old piece of junk compared to other offerings in the market in 10 years time.
If this is actually lead by your desire to have power rather than the currently successful owners will, and you push it, you will soon be looking for a new job.
Oh, how long have most of these disgruntled employees been there and how long have you been there.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Herr vonsteimel,
Pat Primmer said,
"""As one of the old troglodytes actually owns the joint, his will will prevail. While he might agree with you in theory, unless he agrees deep down, when push comes to shove he will not support you. I suspect he really likes being in a custom fab shop AND HE OWNS IT."""
As Pat says, If you do not have the owner onboard 100% you are whistling in the wind.
You have to show the owner what is in it for him, and if he has any reservations about that, you are done for.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them. Old professor
I would recommend that try to have some heart-to-heart discussions with the owner. Ask him for examples of how he thinks HE might have to change. Test him to see if he really believes that this change must START with him and flow down from there. Listen to his words. Is he saying "WE" have to change, or is he saying "I" have to change? has he ever had any personal experience in a large scale successful manufacturing environment? Does he have a model in his head of how that would work? Of how it would be different from how he is doing things now? Or is he just picturing an end goal of widgets pouring out the door by the thousands without really understanding how to get there?
Bootmills: I've got the org-chart/flow-chart but now I have to decide how to briefly describe its use & where to put it. My first notion is the personnel manual... But this is the main question; how to other companies handle this?
How do other companies define their management structure & it's application/use? Where do the put such a definition? A simple org-chart doesn't tell much about the duties of each "position" and the relationships between them. Do they just rely on word-of-mouth? (i doubt not) I know it's not handled with a strict & exacting rule book but any input on the actual question would be appreciated.
VS
PS: Those who say "if the owner/manager doesn't back you up 100% you have no chance of success" are full of it. What matters is 3 things: 1) that the owner/manager admits that they aren't sure how to fix the problem. 2) They trust you & believe in your abilities. 3) They will listen to what you have to say and allow you the opportunity to prove the unproven. *Note: please don't post any response to this Post-script message... Im looking for answers to the above question.
Well, maybe you'd be happy with the ISO model, where everyone has a formal written job description, that they can cite mostly from memory, and can explain in excruciating detail when challenged by an auditor.
Each job description defines from whom one accepts orders and to whom one gives them, so an org chart is encoded in the complete set of job descriptions, even if it is not graphically documented.
It's important to understand that everyone does _only_ and _exactly_ what's in the job description, and that "does everything", "does as asked", "jack of all trades" and such are not acceptable. The descriptions have to be so detailed that, e.g., if someone doesn't show up for work, a lawyer could read the job description and do the job in a satisfactory manner.
In a complete set of ISO documents, the job descriptions may refer to other documents, typically standards and procedures, and the documents' references generally form a tree structure, with the company's mission statement at the apex.
I've seen such a set of documents produced, in about three years. I think you can buy template sets, but you still have to customize the instances to your specific operation; figure a man-year at least.
Mike Halloran
Let's try again.
I do not like you term "fab-shop/retirement home". Your guys are what I would call hackers. Your company needs to move from a hacker mentality to a manufacturing mentality. This is more complicated than it looks.
Hackers sit at their workbench and they hack with stuff until they get it working. They do not follow drawings very well if at all, and they don't like writing stuff down. Perhaps this was your job!
On the positive side, hackers will build one-off systems rapidly, at minimum cost. If they know what they are doing, they can do very high quality work.
On the down side, hackers do not have the discipline to work as part of a manufacturing team. I am generalizing here. They want to build stuff. They don't like generating pieces of paper. They like being in control of their work, which makes them reluctant to follow the instructions on your pieces of paper.
In a manufacturing organization, a whole bunch of people have to work off the same set of information. This means you have high quality documentation, and everybody uses it, and builds to it.
Org. charts are a tiny, semi-relevant detail, that would have gotten you fired by Henry Ford.
You need to take charge of engineering documentation. You need to make your designs and drawings of high quality so that everyone trusts and respects you.
You need to set up an excellent change request system. When someone reports problems, you need to respond to them promptly. You have to treat all the old hackers with respect, and your system has to work. If it doesn't, they will work around you.
It does not matter if the boss respects you. He respects all his old hackers too. In a confrontation, there is no guarantee that he will back you rather than them. It is much less likely if they are right and you are wrong. Never forget that you are reducing their control over the work they do.
Welcome to the wonderful world of office politics.
JHG
Wrong, however I do like to consider all relevant facts before making recommendations. A lot of facts where missing from your OP despite its length. That in itself leans toward a conclusion that could be jumped to.
Actually I have, far to many times. I think the first one was Management by Objectives, Last one was when I actually rewrote the Mission Statement and Quality Manual including organisation chart and job descriptions into a relatively realistic document. hmmm whose jumping to conclusions now.
Unless your a verbose boffin you could probably actually do it in about three or four short sentences.
Actually it might as we would have enough of the picture to make informed recommendations. And just for the record, I did not jump to conclusions, I simply asked relevant questions.
Mostly by useless lip service which is the reason for my questions.
The best place to start is to walk around and ask people what they are actually doing, and what lead them to do it. Find out exactly what happens and why and then think about the impact of changes.
Sadly it sounds like you will find out the hard way that in fact they have been there, done that and are spot on.
When and only when you buy this site will I follow posting policy set by you. Until then I will stick by the policy of those who actually OWN IT.
If the above is not acceptable, please type your acceptable answer here so I don't get it wrong next time. That way you can get the exact answer you want.
Pat
for site rules
I've found that if you want to create accountability you have to designate authority, which adds up to responsibility in the end. In other words, nobody wants to be accountable for something they have no control over (a no brainer, eh?)
So, we're going to assign "areas of responsibility" in the factory (which is setup in a cellular fashion) which are formally assigned to each individual "bay member" (or cell member). The managers will then be formally assigned responsibility for a series of bays/cells. Along with each "formal assignment of responsibilities" we will define some key criteria which they are expected to meet & will ultimately be judged (by their supervisors).
bigTomHanks: lol, funny. But it's backwards from what I've actually been experiencing. The employees fully support the concept but are questioning whether or not the president will actually follow it and allow True authority to be designated -- which I already know he will not 100%, but he will through time after encouragement & help from EVERYONE. It's about creating unity (but not a union) within the factory so that we work towards a common purpose -- Your first remark was waaay out there too. It's not about the employees "bypassing" me (which they should because I am not their manager), it's about the president "bypassing" the "assigned" supervisors... Sounds like you're a little sour from your own experiences. You also seem a little short on management knowledge too, no?... We're all merely "a cog in a wheel" at some level.
I have held much discussion with the owner about my role and am confident in the direction I'm taking it. Our business needs structure in order to expand, not engineering designs. Without the proper structure, we cannot control to quality nor the integrity of the "engineering designs" & the corresponding documentation.... It's not that the owner has no "desire" to deal with the aggravation of business expansion, he doesn't have the knowledge nor the people-skills required to advance the business beyond this point.
Before, he was able to micro-manage the business throughout the development stage but now the business demands far more than anyone could ever micro-manage and "the wheels of time" have reduce his abilities to micro-manage as well. There is a point at which a single individual cannot keep up with the demands of micro-management, no matter how knowledgable or good they are (esp. in a fully encompassing business like ours). We are at that point. and either we stay at our current position (business-wise) and let all our potential go to waste, wait for the owner to die and then go find other jobs --- or we rally together, setup what needs setup, unite our cause and you'll be seeing us in the 2020 superbowl commercials.... and we're not willing to stand and wait so that only leaves one alternative...
VS
As for the comment that a 'flat' structure makes teamwork impossible and ruins morale, well, if that is your starting assumption, you're guaranteed to avoid success.
Mike Halloran
If you put it in the manual use job titles not peoples names.
We just had a revision of the policy manual and training classes. I never saw the org chart.
You say in your original post you have 15 people in the company.
"""There are 2 assumed managers in the factory (1 for assembly/fab & 1 for composites) but their roles are blurry and informal. We created a "chain of command" diagram several years ago but it was never followed. Now, after working with the owner, I've been tasked to do what’s necessary to get things in shape. One of the first things I intend to do is reenact this "chain of command" and get it working. The owner has agreed to follow any such "structure" but will take some work to get it fully implemented. One of the pros of such "chain" is the reduction of people dealing with the owner, which will be limited to just a few managers. It then becomes much easier to foster a positive owner/manager relationship when only dealing with a few individuals. It also will act as a "check valve" to prevent the "poor people-skills" from flooding the factory & drowning moral."""
With two "Managers" it would appear that no one manager has more than seven or eight people under him.
This would essentially make that person a group leader, or working foreman rather than a manager. A company of that size simply cannot afford more than one, or at the most two nonproductive personnel.
Adding layers of management to a company of that size would almost certainly guarantee its demise.
B.E.
You can't organize the company now to have the structure it will need if it were to grow to 100 employees- it will be too top-heavy to survive the transition.
In my experience, a flat management structure works better to foster collaboration and teamwork than a hierarchical one does, as long as the size is limited and everyone is properly motivated.
You imply that the owner's inappropriate intervention and lack of people skills are the source of the problem. Only the owner can solve that problem. Even though they may admit to being the source of the problem in their quiet, saner moments, ownership will ultimately prevail and intervention by the owner is inevitable. The managers you intend to insert between the owner and the workers will therefore ultimately have responsibility without authority- the definition of destructive stress- and are therefore unlikely to be successful.
Pat
for site rules
I should have mentioned that the factory is in 2 separate buildings. Composites fabrication in one and assembly/fabrication(basically everything except composites) in the other. So the idea of the 2 managers is 1 for each building. And then the office, in which we will appoint a "leader" i suppose you could call it. The difference being that the "factory managers" will no be taking on jobs themselves, but rather managing & helping everyone else with their job. Where as in the office, the "leader" will be doing their own work but will also be responsible for the functionality of the office as a whole. They will decide how to split the workload in the office & do the "fire-fighting" in the office, and ultimately be responsible for its performance.
It is going to be a flat structure, with only 1 layer of real managers. However, it is also going to be built-in that the current "bottom-level" factory employees will become managers of their area when we expand to that point. -- As I mentioned, all the factory employees are assigned a work-cell/bay. They are in-fact "bay managers", but they are not called such or else the whole factory would be made up of "managers" (which it is essentially).
So, say we have Joe doing all the engine build-ups & installations. (in reality he IS the manager of that engine bay. he is responsible for the entire engine bay and all that goes on there) When it gets to the point where Joe can no longer keep up with the demand for engines, we'll hire a new person & put put them under Joe. Now Joe is a manager) This will happen for each & every bay.
The newly appointed factory managers will walk around and ensure everyone manages their bay correctly. There main job will be to "jump-in" and help the bay-member before it becomes a bottle-neck. They will also be the ones "representing" their "building" when discussions or problems arise that require the owner.
Berkshire: The "managers" we have now are more team-leaders than managers. But the factory desperately needs managers for a number of reasons I'm not going to discuss here. The new "shift" will make these team-leaders into managers, giving them authority to change what needs to be changed but also holding them accountable for the factory performance.
VS
You need to understand each and every process required, real or imagined, to supply the company's RVs to the public, i.e., the company needs some process engineering to document responsibilities, establish your org chart, etc. I'm guessing people already know what their responsibilities are and who they communicate with and why because it's an established business. Have them write their own job description, since it's a small shop. This exercise might reveal some surprises. I wouldn't move forward without this exercise.
Each organization chart I've seen was in an employee handbook, with varying degrees of detail on job descriptions. Even with heavy amounts of documentation, companies still have trouble getting work done and a lot of other issues to varying degrees of sanity. Why? People.
What you are trying to accomplish is culture change and documentation saying what you want is only a small part of culture change. It takes years of very patiently working with people to accomplish it.
Who says the company is ready to expand? Market analysis? Stable product?
Your references to the retirement home mentality reveals a lot of where your thoughts wander. That will show to others. After you've been around for 40 years running a company, check your thoughts.
As an observation, you state the complete lack of leadership but surely there is some leadership because they've been around for 40 years and managed to get RVs out the door and haven't been run out of business with defects returned by their customers. They've done quite a bit correctly.
If teamwork and morale are breaking down, it is not because of a flat structure in a company that size. Something else precipitates that.
Pamela K. Quillin, P.E.
Quillin Engineering, LLC
I have found 4 jobs in 4 years and landed at this big engineering firm that has these my goals/match corp goals.
1st - what a waste of time
2nd - have no choice but to make my goals match corp goals
3rd - I believe at end of year, I will get a good laugh where this exercise will be meaningless
Big Picture - boss thinks that I do a good job, and his boss thinks I do a good job, so what is the point of this exercise? I am clueless, think at end of year I will be slammed for not meeting their goals, just so they won't give me a nice payraise.
Cheers
Greg Locock
After that, if someone comes to the owner with an issue in bldg 2, the owner brings Sue in to address the problem. This only needs to happen a few times before people will realize the owner will redirect the query to the correct person and they will end up talking to that person anyway. The only person needing the discipline will be the owner.
A word of caution - unless you are building 30-50 vehicles a WEEK, you ARE a job shop/fab shop. Don't invest in onerous processes that are not going to yield benefits.
Short of doing just as you've advised, I'm looking to do somthing more formal to help initiate the culture change that must follow. This is what the "personnel manual" was about. That more than just a verbal say-so is behind the new Chain of Command.
And also, it mainly pertains to information traveling down the chain of command rather than up. But it still applies both ways.
So far things are going well. A consensus has been gathered, from which a set of new changes were drafted. Everyone is very positive and hope it is the real change everyone is wishing for.
VS
"I drank what?!" Socrates?
