Save-as w/o closing drawing? NX7.5, TC8
I have searched the forum and cannot find a solution to this problem. In NX5 I could load a non-master drawing and make changes to it. Then I could switch to the master model and perform a save-as to the next revision and all was fine. After moving to NX7.5 and Teamcenter 8, this is no longer possible. When attempting the save-as I get the message:
Incorrect Revision of a Non-master
A different revision of the non-master part files is already
loaded in the current session.
You have two options:
1. press ok to close the non-masters (without saving)
2. press cancel to abort
Both of these options are bad because I lose the work I did on the drawing. I can avoid this by doing the save-as before making modifications to the drawing, however this doesn't always happen because I am used to the old way. Is there a customer default setting or something that will correct this problem?
