ANSI/ASME B36.19M-1985 Schedule 40s tolerance on wall thickness and OD
What is the tolerance on wall thickness and OD for Schedule 40s pipe (stainless steel)?
RE: ANSI/ASME B36.19M-1985 Schedule 40s tolerance on wall thickness and OD
I have to fit a part into a 2" BSP pipe Schedule 40s. I know the nominal wall thickness and OD but no idea what the tolerances are so cannot determine the minimum id of the pipe. I have no access to the 2" BSP pipe to measure it.
If I new what the tolerances were I could calculate minimum id. Don't what to give too large a margin for error or the part will end up being a very loose fit.
What are you allowing for the weld distortion of the pipe?
Cheers,
gr2vessels
You can usually supply the heavier schedule (80 in place of 40) and not violate the tolerance
Plymouth Tube
