Gear Ratio needed
Gear Ratio needed
Looking for confirmation, making sure I am ok with my design:
I have a two gears design.
The Driver gear which will be connected by chain to a Driven gear. My Driven gear will have a shaft on it that I need to rotate (2) 180 degree turns.
I believe my Driver ratio should be 2:1 (i.e 40 tooth, Driver & 20 tooth Driven), am I CORRECT?
Just double checking.
Thank you..
Thank you..
RE: Gear Ratio needed
That being said, I can't help but wonder that if this is the level of questions which you need answered, then I can't see how you can possible fit the profile for the intended uers of this site. Eng-Tips is an information exchange and engineering help site intended for use by professionals currently filling some sort of engineering or technical role, either as entropronetuers or as part of some larger organization where they are empoloyed.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Ted
Mike Halloran
Pembroke Pines, FL, USA
If the driving gear is twice as big then twice the speed - 1/2 the horsepower. Does that help??
i mean it's pretty obvious (no?) that a gear with 1/2 as many teeth as it's meshing mate will be turning twice as fast.
adding the fact that it'll have 1/2 the power (well, it's 1/2 the torque isn't it ? ... isn't the power the same ? Torque*omega ??) probably doesn't help understand the gearing question.
mind you the question is confused by explicitly stating "My Driven gear will have a shaft on it that I need to rotate (2) 180 degree turns." what does that mean ??
My first quick and dirty assumption is that power is constant through a gear train, or is affected only by efficiency. Torque and speed vary.
I do agree with JohnRBaker, above.
JHG
Ted
I didn't really think I would get some of the (to me) rude comments. I would rather people (professionals) who don't have a proper comment to add, just not post. If my posting offend anyone for any reason, feel free again not to comment.
Thank you for those that posted decent comments and well the rest (you know who you are), please again keep you insensitive comments to yourself.
Didn't think I would EVER have to post a comment like this on this SITE, again, I figured everyone here is PROFESSIONAL.
I thought a few of the comments could be considered...uhhh...gratuitous. Just my opinion.
Mike
