suction of minimum 25m3/h exhaust gas
I am currently designing cleaning system in which I need min 25m3/h exhaust gas. I have tried different mechanical pumps (side channel blower and piston air blower) all of them breaks down after few operating hours due to dust in the exaust gas.
I am considering using a water jet pump but I cannot find a suitable one with relatively low pressure and flow. I have a water floof app. 10 m3/h and the discharge pressure should only be above 150mb. Other solutions could be used as long as the can handle dust without breaking down. amout of dust is approximately 5 grams pr hours at 25 m3
If someone could help me I would be very happy.
regards
Klaus Damm Kristiansen
RE: suction of minimum 25m3/h exhaust gas
The next thing to try, IMHO, is a Nash Liquid Ring Vacuum Pump.
Mike Halloran
Pembroke Pines, FL, USA
You could also try an ejector (like the jet pump except it uses a compressible power fluid). It would require power gas pressure (compressed air or steam) about twice the exhaust pressure and you need a mass flow rate of power gas about twice your required suction mass flow rate.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
