SW09 Hole Table Location Precision
Greetings.
If I have a part with variety of hole types, how can I create a table that displays different levels of location precision?
For example, I might have fab or burn out clearance holes that would require a location precision of (2) decimal places, or drilled and tapped holes that require a location precision of (3) decimal places, and dowel holes requiring a location precision of (4) decimal places. How do I change one or two location precisions without changing them all?
Thanks in advance.
Ferris.
Thanks in advance.
Ferris.
RE: SW09 Hole Table Location Precision
Does that answer your question? I'm not quite sure what you'd need a table of values for...
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems." -Scott Adams
It seems to me I did this a few weeks back and it was very simple. I simply edited properties for the select hole locations. However, when I try this today I change the properties for the entire hole chart.
Select the cells you want to change the precision on and change it over in the feature manager on the left.
Not sure if SolidWorks 2009 had the capability. It has been added recently. Not sure what year.
Cheers,
Anna Wood
SW2011 SP5, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
Can you post your files and also a screenshot of what you are looking at?
Cheers,
Anna Wood
Hardie "Crashj" Johnson
SW 2011 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
We will be upgrading to 2012 soon. I look forward to the newer version.
Thanks for all replies.
