transform pattern to a symbol.
Hello, We're running nx 6.0.5.3 and we received some sample notes and title block from our colleagues however they come in as a pattern. I would like to transform this piece into a custom symbol for future use. When I try to edit the pattern I don't have the master pattern they are patterns added to a drawing as a sample and the options provided are in German and with no experience in patterns I'm in over my head.
NX 6.0.5.3 in Windows 7
Mechanical designer
RE: transform pattern to a symbol.
If that is the situation then what I would do is a cgm export of what you want in the symbol, and then bring that into a clean file, and make the symbol from that.
I have never run into the problem of not being able to make a symbol from a pattern, so I am not sure if I am on the right track here or not.
Mechanical designer
Mechanical designer
