Steel I beam sizing
Steel I beam sizing
I am planning a 30 x 32 garage build and need help sizing a steel Beam for a 32'clear span that will support an upstairs with 50psf LL and L/360 loading condition, there will not be attic storage above the floor. I intially thought I would need a W16x36 but I believe that my math may be wrong. There will be 2x10 floor joist 12" OC attached to this beam.
RE: Steel I beam sizing
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
STRONGLY suggest an intermediate column if possible.... then a W10 x 15 works quite nicely...
Get help - as mentioned....
