BURST-OUT STRESS, METALLIC PLATE
Fellow stress engineers:
Do any of you know of a method for calculating the stresses induced in the ligament by a fastener loaded such that it is tending to burst out through a straight-edge? I have the means to calculate the RF in the form of allowable load divided by acting load, but that's not what I want this time.
Thanks in anticipation.
RE: BURST-OUT STRESS, METALLIC PLATE
look up "shear tear-out" in Bruhn, Niu, etc
Thanks, rb1957, but Bruhn & Niu produce the RF I described above. I'm hopiing for a "strength of materials" type approach for estimating stresses in the ligament.
i'm not sure what the difference is ... Bruhn calcs the allowable fastener load due to shear tear-out, to be compared with the applied. indeed the allowable load is "just" Fsu*As, (eqn 3, pg D1.6) where As is defined by the geometry of the hole and the edge.
don't see how this is an RF result ?
if you want the allowable stress is Fsu, and shear stress = P/As ...
Bit late to the party, however, have you solved your problem?
As suggested above by rb1957, I will check the lug strength for statics. Correct me if I am wrong, but strength of material approach will lead to Net section calculation, which do not consider location of the hole.
Are you looking at performing Fatigue analysis with the re-assessed stress? In which case, I would tend to you lug SN for fatigue analysis.
Let us know if you got something else to evaluate stress in ligament (ESDU etc.)
Best Regards,
SAjet
