Stress-strain diagram for S235/S275/S355 steel grade.
In my analysis I need to input true stress-strain data in material module. Where can I find, let's say nominal stress-strain data for steel grade S275?
Example data I need:
https://dl.dropbox.com/u/3745405/stress_strain_cur...
RE: Stress-strain diagram for S235/S275/S355 steel grade.
Here is a tip, if you need specific tensile test data have tensile testing performed at nominal cost using actual material. This way, the data is defendable.
there are several paid services, in our country it is this. look for astm book. or search sciencedirect for data source.
All about materials
http://materialing.com
OK. Thakns.
Does anyone know where can I get Stress-Strain curves for S275 steel according to the Eurocode 3?
