Underground Pipe Wrapping Inspection
Hi everybody.
I want to know which parameters should be checked for inspection after UG pipe wrapping application, and how long after applying wrapping, the pipe should be sandfilled and backfilled (buried)? Does the sunlight damage the wrapping tapes?
Thank you.
Thank you.
RE: Underground Pipe Wrapping Inspection
If the material has been formulated with carbon black and other UV stabilisers, a few weeks in the sunlight won't do it any harm.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
