ASCE 7-10 Figure 28.4-1
I am looking at the low-rise envelope method in ASCE 7-10, and I am confused about it. They changed the cases from longitudinal and transverse to Case A and Case B. Case A does not include any sidewall pressures and Case B does. It seems to me that Case A is nothing more than Case B without sidewall pressures. Is that right? If it is what is the point of Case A.
Also, there is nothing showing the 2/3 roof zone boundary when the wind is along the ridge, but the Note 8 is still there defining that transition, but the pictures don't show it. Am I missing something, or is there a mistake? The latest errata I have is from January 2011, and I can't find anything more up to date.
Does anyone have a resolution for this?
RE: ASCE 7-10 Figure 28.4-1
Case A perpendicular to the roof apex generate global shear
Case B parallel to the roof apex generate no shear, just local pressure on wall that must added to interior pressure.
Case B is important in moment frame design.
Of course it depend of the geometry of the building (width of each frame side)
There will be global shear since both opposite faces are of different signs (i.e same direction).
- Case A generate a global Shear,
- Case B generale no global shear. See Pressure 1 & 4.
Of course Case B generate shear but in the other direction lateral force resisting system.
