Mechanical/electrical: Modifying drill for medical research
I need to modify this drill which has a 15,000RPM to a 2,000RPM. I am researching this as an alternative to the current expensive drill used for drilling into skulls for cochlear implants. While we could purchase a drill that is already at 2,000RPM, this particular one is nice because it is inexpensive and it's small and easy to stick in someones head. Any ideas on how we can modify?
Thank you!
Kayla Foyt
Thank you!
Kayla Foyt
RE: Mechanical/electrical: Modifying drill for medical research
Cheers
Greg Locock
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies to make the best use of these Forums?
Whats next.. a car jack for a rib spreader.. A steak knife instead of a scalpel.
Dear Dremel Company,
Please advise as to the best method to remove skull fragments from the internal gearing on your Stylus line of products.
Sincerely,
Doctor Doom.
Option 2: Find out the hard way.
