Problems with LabView 2010
Recently, I have experienced problems with a VI that was written to transfer data from a custom multi-axis testing platform to the computer. The problem was not noticed until the LabView program was updated to the LabView 2010 version. Does anyone know how to get data through the serial ports on LabView 2010? It doesn't have to be relevant data to what I am doing. Our problem is just figuring out how to get LabView to recognize data on the newer version. Thanks!
-Clay Hillyard
RE: Problems with LabView 2010
Run time exe or within the LabVIEW development environment?
Any errors reported?
Same OS and PC?
I have migrated an application from 8.6 to 2010 that used serial routines without any issues.
-AK2DM
"It's the questions that drive us"
No it's a different PC. We believe the problem lies within the specific sub-vis that we are using (serial ports), but we are not sure what the problem is.
-Clay Hillyard
COM port assignments not the same? An error number or description would be useful to troubleshoot further.
-AK2DM
The COM port assignments are the same; however, my error number is (Hex 0xBFFF006B). Does this help?
-Clay
Error 1073807253
Was VISA installed when LabVIEW 2010 was installed?
-AK2DM
Yes, Visa was installed when LabVIEW 2010 was installed.
-Clay
Clay:
I am coming up empty here. What function throws the error?
All I can suspect is one of the default settings for an unwired input in one of the standard shipping vi's was changed. That is typically frowned upon.
Have you tried using Windows Hyperterminal or equivalent to communicate with the tester to verify port hardware, settings, and cabling? IF that works then verify that COM settings in the program match.
There are some serial rountines that ship with LabVIEW (BasicSerialReadAndWrite), search the examples in LabVIEW for serial.
-AK2DM
