Drafting - Equidistant dimensioning symbol
Good afternoon,
I am using NX7.5 and drafting in the same file as the model. I want to add equidistant dimensions / symbols to 2 points either side of a centreline.
Can anyone tell me how to do this please? I can add 2 dimensions which have the same value, but how do I add the '=' sign strikethrough the dimension line?
(did that make ANY sense ?!?)
Any help is gratefully received.
I am sure the help documention would tell me this however I do not have the luxury of it being installed on my machine.
Cheers,
Rich.
RE: Drafting - Equidistant dimensioning symbol
Is it possible to post a pic of what you want the dimension to look like?
It would also be helpful to know what drafting standard you are working with.
www.nxjournaling.com
Easy one: select the 2 entities for your single dimension then, while still in dimensionning, hit the arrow-left key: you'll have access to a small on-screen input window where you can type "=" then hit Enter; hit then the left arrow and do the same. You should now see 2 "=" signs before and after your dimension. Place your dimension. Done.
If u want only = sign but no dimensions you have to use Edit Appeneded text option and put = in place of dimension
or else the above mentioned method will work fine
Nx 7.5.5.4
Teamcenter 8
You can make the dimensions reference by placing them between brackets like (d1) then appended text before and fill in $h then press enter. Now you will have something like this // (d1).
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
Thanks folks - all sorted now smile
