Hole wizard rounding decimals
I have Solidworks 2011 and it is rounding the decimal place for holes and angles.
I'll input 3.875 and it will show 3.880 when I put it to three decimal places.
For angles when I use a 45 deg angle it won't show any zeroes (like 45.00 deg) only 45 no matter how many decimals I set it to so I have to override the value.
I have to use linked dimensions. Thanks.
RE: Hole wizard rounding decimals
I'm not sure why you're having the rounding issue. You might want to ask your VAR, assuming you're on maintenance.
Jeff Mirisola
Director of Engineering
M9 Defense
My Blog
