Rendering image
Rendering image
I'm trying to render an image of an assy, but i can't get rid of all the planes for each part, nor the indicators for the contraints. I have "hidden" all the contraints, but there are still all these planes, icons and axes all over. How do i get rid of these to get an image of my assembly only?
Any possible solutions would be greatly appreciated
RE: Rendering image
Open Notepad, paste what is bellow and change extention from txt to CATScript then execute.
Sub CATMain()
Set ProductDocument1 = CATIA.ActiveDocument
Set Product1 = ProductDocument1.Product
Dim ProductDoc1_As_Document
Set ProductDoc1 = Catia.ActiveDocument
Dim Selection1_As_Selection
Set Selection1 = ProductDoc1.Selection
CATIA.DisplayFileAlerts = False
Selection1.Search "CATAsmSearch.MfConstraint,All" 'hide Constrains
Set visPropertySet1 = Selection1.visProperties
VisPropertySet1.SetShow 1
Selection1.Clear
Selection1.Search "CatPrtSearch.Surface,All" 'hide Surfaces
Selection1.Clear
Selection1.Search "CatPrtSearch.AxisSystem,All" 'hide axissystem
Selection1.Clear
Selection1.Search "CatPrtSearch.AxisSystem.Name=Axis' 'System*,All"
Selection1.Clear
Selection1.Search "CatPrtSearch.Line,All" 'hide lines
Selection1.Clear
Selection1.Search "CatPrtSearch.Curve,All" 'hide curves
Selection1.Clear
Selection1.Search "CatPrtSearch.Sketch,All" 'hide sketches
Selection1.Clear
Selection1.Search "CatPrtSearch.Point,All" 'hide points
Selection1.Clear
Selection1.Search "CatPrtSearch.Plane,All" 'hide planes
Selection1.Clear
selection1.Search "CATGmoSearch.OpenBodyFeature,all" 'hide geometrical set
Selection1.Clear
Dim specsAndGeomWindow1 As Window
Set specsAndGeomWindow1 = CATIA.ActiveWindow
Dim viewer3D1 As Viewer
Set viewer3D1 = specsAndGeomWindow1.ActiveViewer
Dim viewpoint3D1 As Viewpoint3D
Set viewpoint3D1 = viewer3D1.Viewpoint3D
viewer3D1.Reframe
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208
RE: Rendering image
Anyways, i manages to remove the planes, contraints and axes by searching, selecting and hiding - so i'm all good for the moment!
Thanks again, Fernando
RE: Rendering image
Fernando
