How to get the object of UF.UFModl using NX open ?
Hello everyone ,
I need to get the symbolic thread parameters using NX open code, but to access the API "AskSymbThreadParms" i need to get the object of UF.UFModl.
Can someone please let me know how can i get the object of UF.UFModl in my code.
Amitabh
RE: How to get the object of UF.UFModl using NX open ?
Basic steps are:
  1. import the UF namespace
  2. create a UFSession object
  3. call the UF function from your UFSession object
example code:
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim ufs As UFSession = UFSession.GetUFSession()
        Dim thread_tag As Tag = Tag.Null
        Dim thread_data As UFModl.SymbThreadData
        ufs.Modl.AskSymbThreadParms(thread_tag, thread_data)
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
 'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
End Module
www.nxjournaling.com
Thank you cowski, the solution works perfectly.
I was doing the steps 1 and 2 but missing the 3rd step.
