Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This has been the MOST helpful forum that I have been a part of and I want to say thank you. The tips, tricks and helpful advice that you all contribute to have been lifesavers in many instances..."
Geography
lewisFeng (Electrical)
1 Jul 12 4:26
Dear professionals
I need to build a power tranducer to drive a eletromagnetic buzzer.The residential electricity in USA is 110V 60Hz, I need the output to be 110V 40hz in square wave with with limited output current.
How can I get the transducer, please help, thank you in advance.
MikeHalloran (Mechanical)
1 Jul 12 9:02
What have you tried so far that didn't work?
How did it fail to meet your needs?
Which course is it for?
Mike Halloran
Pembroke Pines, FL, USA
Skogsgurra (Electrical)
1 Jul 12 17:07
A 40 Hz buzzer? What an unusual specification. Is that really what it needs?
If so, there should be a suitable driver (not transducer) available for it.
Mike, all odd questions aren't necessarily school work.
Gunnar Englund
www.gke.org
ScottyUK (Electrical)
2 Jul 12 1:33
Off-topic (slightly): a major chemical complex near me used to run its distribution network at 40Hz until fairly recently. It was a legacy from the early days of the industry when plants used to generate their own power and there was no grid. Latterly, rotary frequency converters were used until these were finally retired. This part of England was an early adopter of industrial electrical power for mining and heavy manufacturing, and there were all sorts of little curiosities like the 40Hz system and true 2-phase distribution. Gradually the oddities are disappearing as standardisation continues.
2 Jul 12 8:10
Actually, I'm a antenna designer.The project is a buzzer array work on 40Hz. The passive electromagnetic buzzer should be drived with the external signal with 40hz 110V AC, and the preferred waveform is not sine wave but half square wave. The question is if the power is 60hz 110v AC, how do I change it to the working power for the buzzer.
2 Jul 12 8:41
Mike, I start thinking you may be right.
Gunnar Englund
www.gke.org
2 Jul 12 8:46
1: Use a VFD.
OR
2: Rectify it to DC, then switch it on/off. You may need to insert a transformer before the rectifier to get the output voltage correct. You'll need a solid state switch to live with the duty cycle.
You probably won't get square wave voltage with the buzzer connected, because its inductance will fight you. Of course, that's a guess, because you haven't told us squat about the buzzer, e.g., its DC resistance, current demand, power demand, whatever.
Mike Halloran
2 Jul 12 9:51
I haven't see any commerial VDF change 40hz to 60hz, maybe it should be customized designed.
The total amount of buzzers is about 100 pcs. So the average power consuming maybe more than 300w, and the average current maybe more than 2.5A, the instantaneous current maybe higher.
Because the system is single frequency working, I'll try to conjugate match it.
2 Jul 12 11:35
Huh?
Mike Halloran
Comcokid (Electrical)
2 Jul 12 21:29
Your signal diagram shows a popular method by which the AC creation stage of a DC-to-AC inverter works for taking two triange waves, one DC offset above the other, and using it to chop a low voltage reference sine wave into two PWM signals used to drive a H-bridge to turn a high voltage DC into a higher voltage AC signal. It still needs a low-pass LC to filter it. This is also the approach used for PWM sine-wave motor drives.
Now, if you need 40Hz at 115VAC, I suggest that you take a Variable Frequency Motor drive, and set it to produce 40Hz, or hack a true sine-wave analog-circuit inverter to substutue a 40Hz reference instead of the 60 Hz reference. You might also take one of the microprocessor-based AIMS inverters and substitute a crystal that is 2/3 the frequency of the existing crystal and get it to produce 40 Hz.
Close Box
Join Eng-Tips® Today!
Join Us             Close
