Temperature range of bolts and nuts material
I would like to have table that can show the temperature range of bolts and nuts material (B7,L7,B8/2H,2,4...etc)
Best regards,
RE: Temperature range of bolts and nuts material
Check CSA Z245.15, ISO 15156 maybe. I'm sure API 6A only talks about it. Try the various manufacturer or ask your supplier. Using this forum for this request probably not the best way on this question.
Cockroach
Cockroach,
Thank you for putting me on the correct path,
Temperature range for what - strength, corrosion resistance? What's wrong with starting at ASME II, Part D followed by ASME B31.3, Table A-2?
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
EN 10269 and ASTM F 2281
