Elastic Section Modulus or Plastic Section Modulus?
What is the difference between using Elastic Section Modulus (S) and Plastic Section Modulus (Z). I am desigining a base plate which happens to work if using Z, but it does not if using S. I am working usin Limit States Dedign (Canadian Code). Thanks for any input..
RE: Elastic Section Modulus or Plastic Section Modulus?
That means that when using plastic section modulus, I am using the full capacity of a section; so if using elastic instead of plastic, am I being just conservative? or what other implications may have using one or the other?... Thanks again
The section modulus S would be used for determining stresses within the elastic range. It is also used in determining Mr for Class 3 sections (not applicable to a base plate).
Look at page 1-33, Article 13.5 in your CISC Handbook of Steel Construction.
BA
