TCL for post building
I am trying to build a certain header in NX post builder and am kind of stuck on a certain part.
Recently started using expressions to create a master model so everything is looking at one model instead of changing a bunch of different things or repointing when there is a rev change etc..
I have it so i can pull the expressions for the part number,part revision, and smi revision into the post and pull in the date and time through a seperate custom command.
Now we have some files that wont be switched over to the master model theory as they take weeks to program and wouldnt be beneficial. Does anyone know a custom command that could be used that says if its not using these expressions/cant find them then dont put anything?
Thanks for any help.
RE: TCL for post building
Thanks.
http://www.eng-tips.com/threadminder.cfm?pid=561
Plus, I suspect Catia would dispute your claim about NX being more popular in aerospace.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Thanks again.
