Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I also believe that we all can contribute to each other's growth by sharing knowlege and experiences. I would love to take my skills and help people around the world solve problems..."
Geography
kristoffon (Mechanical)
29 Jun 12 10:33
Hello gentlemen, I'm trying to produce a heater element to be incorporated into a steel valve body to maintain fluid temperature in the 1000K ballpark. Obviously I can't simply pass a copper wire so I'd be very grateful if anyone could give me the commercial names for the materials commonly used in heater elements as found on electrical stoves, etc, that have the steel pipe which glows red, ideally with some sort of internal filling to fill the air space inside for optimal thermal conductivity between the copper coil and the casing.
Thank you very much.
Goahead (Aerospace)
29 Jun 12 11:20
You may wish to see the answer provided by scientists to a question similar to yours:
http://www.newton.dep.anl.gov/askasci/mats05/mats0...
http://www.welding-advisers.com/
IRstuff (Aerospace)
29 Jun 12 11:29
What do you mean by heating element material, the heater itself or its insulation?
Typically some thing like nichrome does the actual heating, and a variety of ceramic materials are used for insulation
TTFN
SnTMan (Mechanical)
29 Jun 12 11:35
Calrods
29 Jun 12 12:14
IRStuff, I mean the insulation. The heating element is easy enough to make out of copper or steel wire if necessary. If you could give me a name for that ceramic so I could look for it, that'd be great.
Thanks for the replies so far I'll check them out.
29 Jun 12 12:21
Just to add, the power requirement will not be high. Something on the 5000W ballark which might not be trivial but I don't think would require any out-of-ordinary materials.
Helpful Member!  EdStainless (Materials)
29 Jun 12 13:26
Watlow and Calrod are two of the big manufacturers of electric cartridge heaters.
the outer sheath is usually alloy 800, the heating element is nichrome or a similar high temp high resistance alloy, and they insulation is magnesium oxide. They string the wires inside the tube and fill with powdered oxide. Then they draw the tube down to a smaller diameter to consolidate the insulation.
Buy them, these are highly engineered products that rely on specific relationships of heat transfer and electrical resistance to function correctly.
Plymouth Tube
29 Jun 12 15:00
Thank you Ed. I should've realized those heaters could be purchased way before posting. That's what I'll do.
Close Box
Join Eng-Tips® Today!
Join Us             Close
