Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This is easily the most helpful website I've ever used, and this is the best forum with the quickest response time bar none...."
Geography
dtwo (Automotive)
29 Jun 12 9:40
What is the best rod to use when welding cast steel (specs unknown) with A36 structural angle? The weld will not be considered strucutural.
swall (Materials)
29 Jun 12 9:44
You need to find out the carbon and alloy content of the casting. Until you have that information, discussion of a welding procedure is premature.
stanweld (Materials)
29 Jun 12 10:12
What is the welding process? If not structural, what is it considered?
dtwo (Automotive)
29 Jun 12 10:16
Tack welding the structural angles to machine base to prevent possible movement.
Goahead (Aerospace)
29 Jun 12 10:37
Tack braze welding by oxyacetylene flame using a bronze rod and suitable flux may do the job without melting any of the base metals.
http://www.welding-advisers.com/
dtwo (Automotive)
29 Jun 12 13:58
The cast material is a ductile iron 80-55-06. This is approximate as the material I was given is a Europeon standardard (EN-JS 1050).
swall (Materials)
29 Jun 12 14:32
To tack weld 80-55-06 ductile iron to steel, use Ni-Rod 55 stick electrodes.
dtwo (Automotive)
29 Jun 12 14:40
Any preheat of the iron required before welding? Thanks for the information.
weldtek (Materials)
29 Jun 12 15:11
According to one manufacturers spec this material contains ~ 3.5 C so you should consider preheating and slow cooling. Id suggest around 400F for preheat.
swall (Materials)
29 Jun 12 15:25
I have seen various manufacturer's literature on these nickel electrodes stating that pre-heat is beneficial, but usually not necessary. It does no harm. I have never seen a recommendation for slow cooling.
Helpful Member!(2)  metengr (Materials)
29 Jun 12 23:11
I would suggest you review the information below for welding ductilr iron:
http://www.ductile.org/didata/Section8/8intro.htm
unclesyd (Materials)
23 Jul 12 0:08
If I could count the ways to successfully weld the irons to Carbon Steel.
The information posted by [b[metengr[/b] is very good and should be used if possible.
In our old textile manufacturing plant we had to weld all the irons to CS. We welded Ductile, Malleable. Meehinite, and many others, some for the thirties.
The only absolute way to weld the Irons to CS would be to heat the materials to above 1325°F and weld at temperature. As this is normally impractical, an alternate approach is to weld “cold”, in other words get the heat input down by “painting” the metal instead of welding. This is possible due the filler being so much stronger than the base iron. This process takes a little getting use to by a good welder because it profanes all he has learned about welding. The success rate is very high even on some of the older oil soaked irons. On very dirty iron we will try to run them through the Pyrolysis Furnace to achieve the cleanest surface possible.
We use a Chronotron electrode 210 or a Certaium 889
Close Box
Join Eng-Tips® Today!
Join Us             Close
