Tube Function NX7
Tube Function NX7
Tube Function NX7
Is there no tube command in NX7. I use it all the time in NX5. I know I can do a sweep with circles but was just wondering does it exist? maybe called something else?
RE: Tube Function NX7
In NX 7.5 it is still called tube (Insert -> Sweep -> Tube). If it is not in the insert menu, try using the command finder.
www.nxjournaling.com
Just a tip:
If you have trouble finding where a command went then go to:
Help -> Command Finder
ad enter what you are looking for, it will tell you where it is.
