NX Postbuilder... a simple question
first of all: sorry for my bad english :)
I am using NX postbuilder since a few weeks.
We get some new machines and i edited some postprocessors.
We have some different Heidenhain TNC 530i-Controls on different machines.
DMC 104V linear, DMU 80 monoblock, AXA VPC-40U and AXA DBZ.
Each machine has its own postprocessor due different homepositions, etc.
An each 5axis mill hast 2 PP's for 3axis- and 5axis-programs
To see in Fileexplorer i added the name of the pp in the file-extension of postbuilder.
for example:
programname.h - is the standardname. But in this name i can't see from which PP it is.
so i changed extension in Postbuilder to:
programname.VPC-3AX.h - for a program from the PP for AXA VPC 3axis
But on some older TNC530i's i have problems to see this "double-extension" in filemanager on machine
or in TNCremo. In some cases the machine is shutting completely down due the transfer from DNC-PC to machine.
Is there any in Postbuilder to add words to the desired Programname?
simon
RE: NX Postbuilder... a simple question
I am not a fan of using a second period (or spaces) in file names for exactly the reason you have discovered. Use an underscore or dash to separate the generic name from the machine specific portion.
I do realize that all OSs and applications CLAIM to support most characters in a filename, there is some old legacy code in some programs that hasn't been fixed yet.
Ben Loosli
Hello.
Thanks for your reply.
Yes. I want to get a filename like "programmname_VPC-3AX.h"
But the given name in NX CAM should be "programmname" and the postprocessor adds the "_VPC-3AX.h" specific for each PP i have.
The double period was the fastets way to realize that through the function "file extension" in postbuilder.
But as i explained, with some problems on some machines.
Maybe you have a solution for my problem?
Sorry for double-posting...
With the variable "$mom-output_file_base_name" i get desired filename from nx-cam.
For example:
global mom_output_file_basename
global ac_part_name
set mom_output_file_basename [string toupper $mom_output_file_basename]_VPC-3A
set ac_part_name [string toupper $mom_output_file_basename]
MOM_output_literal "0 BEGIN PGM $ac_part_name MM"
MOM_set_seq_on
This is the section for the first line in my nc programm.
The programm head is then the desired for example
0 BEGIN PGM test_VPC-3A MM
This works perfectly. But i want to set the filename from nx-cam to "$desiredFilename" + _ppName
You know what i mean?
...sorry for my bad english. I try my best...
Found a solution for my "problem"...
In the end of Postbuilder i set folowing custom command:
global ptp_file_name
if {[file exists [string toupper $ptp_file_name]_DMU_5A.h]} {
MOM_remove_file [string toupper $ptp_file_name]_DMU_5A.h
file copy $ptp_file_name [string toupper $ptp_file_name]_DMU-5A.h
So i have a copy of the original with my extension "_DMU-5A.h".
As example 4711_DMU-5A.h
In Postbuilder itself is no extension for the file set.
The initial file "4711" can't be deleted from postbuilder. Permission denied.
Never mind. This solution works for me.
