Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I have never been to any technical site that shows concern just to anybody with problems...I look forward to also share in the future..."
Geography
internal gear pump fixed displaced for around 4.0 e-4 m3/rev.
sarakhan (Mechanical)
29 Jun 12 6:29
Trying to configure a internal gear pump fixed displaced for around 4.0 e-4 m3/rev.
Cant find any suitable pumps on Parker or BoschRexroth. Can anyone suggest something
29 Jun 12 6:49
Perhaps even an alternate to gear pump which will give a acceptable displacement. and furthermore, it needs to be used in hydraulic components such as a forklift... or crane....
micalbrch (Mechanical)
30 Jun 12 4:59
Is that a typing mistake or do you really look for 4 m³/rev (4000 L/rev)?
Compositepro (Chemical)
30 Jun 12 14:47
e-4 = 1/10,000
1 Jul 12 5:04
Got it, Compositepro. Thanks!
Check for laboratory equipment like www.michael-smith-engineers.co.uk
2 Jul 12 17:24
I agree 4e-4 is just too high.
I have a practical question, to work with a double acting piston cylinder (1m Stroke length).
If i want to have a cylinder velocity of 0.5m/s,
1.Is having a pump displacement of 1.5e-4 m3/rev feasible ?
2. and a PRV operating at Pmax= 3e+007 Pa?
3. the pressure that develops in the hoses goes around 5e+7Pa ?
Are these good values????
I want to adjust these 1,2, 3 values to depict a real system. The problem is if i try to make the hose pressure to be around 3 e7 pa then I have to operate prv at 1e7 pa and then the pump displacement goes really high. (4e-4 m3/rev to achieve 0.5 m/s ) and I cant design the hoses drops as no equation is available. Peter here suggests to use some equation for calculating pressure drops but i cant find any relevant scientific papers on it. Please suggest ....
Sara.
3 Jul 12 4:05
We need the cylinder diameter and the rpm of the gear pump to tell you if you can achieve 0.5 m/s with it. Or you do it by yourself. With the diameter and the stroke length you can calculate the volume of the cylinder. With the oil pump's rpm you have the flow in m³/h, m³/min, m³/s or whatever you want.
If 3 e7 Pa means 300 bar (4350 psi) - that is high but probably not too high. What I do not understand is your whole hydraulic configuration. You have a pump at fixed speed which is not VFD controlled, right? The set pressure of the PRV cannot be less than the pressure you see in the hose between pump and cylinder. Otherwise nothing will move.
3 Jul 12 6:12
I just see that you post the same question in different forums! Great! With that you are hiding information to the colleagues who answered here (like me). Good luck with your problem!
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
