Structural Blind Bolts
I have some framing with WF beams mmoment connected to HSS columns. One of ideas of connection is to use the blind bolts. However, I have a lot of difficulties to find something solid about it (USA).
Have someone any experiance with this kind of connection?
HSS Manual is not very helpful.
RE: Structural Blind Bolts
I would stick to the normal bolts. I have welded a plate on the face of a colum that was drilled and tapped for bolts (cap screws with full thread), but that was for a very large piece of equipment. The beams were 1" and 2" built up box beams. I had diaphrams inside some of the boxes. It was not cheap to fabricate.
Used as structural connection on tubes.
I called Lindapter for more info.
I understand the limitation in use, but in some cases blind bolts can be more efficient (cheaper) than other type of connection, with the sufficient strength.
http://www.huck.com
Another system is Flowdrill where a tool is rotated at high speed ad pushed through the steel, forming a swaged cone of material on the internal face. This can then be tapped and bolted in the usual way. Tool cost is approx $1600, but pay back good on volume.
For more check out these sites:
www.frictiondrill.com
www.formdrill.com
www.flowdrill.nl
From my experience the drills run between $50 -$390 depending on size and type of application. And tool life is 3,000 to 40,000 holes depending on material.
www.danly-te.com
