Printable area
Printable area
Printable area
I've made several sheets A1-A2-A3-A4 the printmargins by properties are by default 30-6-6-6 mm
In windows i can change that to 10-10-10-10 mm save the configuration and they stay that way.
With Mandriva I set the same values save it and restart DraftSight look at the printmargins and they are 30-6-6-6 mm
If i look in the folder printsetting and open A3.cfg the margins are 10-10-10-10 mm
Any one know a solution
Regards, Willie
