Equivalent CSA standard for ASTM A449
Engineer specified ASTM A449 anchor rods for a project. Contractor is asking if there is an equivalent CSA standard. Anyone run into this question before?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Equivalent CSA standard for ASTM A449
Can any of our north-of-the-border members help? BAretired? dik?
Dik
And for more recent projects I've specd ASTM A1554 grade 50 for anchor rods. A325, A1554 and A490's are common in most of Canada, with the equivalent Nuts and Washers to match.
Dik
BA
ASTM F1554 | Atlantic Bolt Inc
www.atlanticboltinc.com/F1554.htm
ASTM A449 is the strength level equivalent of A325, and ASTM A354 or ETD 150 is the strength level equivalent of ASTM A490 in a rod specification with more ...
Unless you need really big bolts, I'd stick with ASTM A325...
Dik
