multi file pdfs via journal
What would need to be added to this journal file to produce separate files for each page. Eg. if the drawing number is 25D1064AM could the names be 25D1064AM_1.pdf, 25D1064AM_2.pdf etc for each page. We have electronic engineering stamp procedure and the drawings need to be separated for each page. This journal file was used a lot to output pdf files for internal searching.
NX 6.0.5.3 in Windows 7
Mechanical designer
RE: multi file pdfs via journal
Thank you once again cowski.
Mechanical designer
