Help additional option unconnected_region
Hi, i have a issue. i have made a static analysis and abaqus say me that there are UNCONNECTED REGIONS. i need to find them for the convergence of the problem. Reading the documentation if i add the Unconnected_region=yes in option datacheck, then abaqus create a element set that is named MESH COMPONENT in output database.
My question is how i can introduce this command or is there other way to find this unconnection regions?
thanks in advance.
thanks in advance.
RE: Help additional option unconnected_region
was a silliness
from Abaqus command, you must launch the following:
Abaqus job = jobname DataCheck unconnected_regions = yes
done this, you can see the results of the job and will elemenset MESH COMPONENT unconnected with the regions
