Low Pressure Storage Tank
Can anyone recommend a text for the design of steel low pressure storage tanks? I have access to the API publications, already.
Dik
Dik
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
Low Pressure Storage TankLow Pressure Storage Tank(OP)
Dik Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: Low Pressure Storage Tank
Dik
Dik
1.) The American Water Works Assoc. (AWWA) has some specs. and design guides.
2.) Several of the Civil & Structural Handbooks have some material on the subject.
3.) Any Tanks and Shells, or Plate Structures text. Don’t have one in particular.
4.) Tubular Steel Structures, Theory and Design, by M.S. Troitsky, Pub. by Lincoln Arc Welding Foundation. Good general coverage on many subjects, and inexpensive too.
5.) There are several large manufacturers who design, fab and erect these types of tanks, maybe some of there literature would be helpful for ideas and general details and methods. I’d guess water, sewerage treatment, petroleum, and bulk storage.
Most of the tanks built are built by specialized contractors who have their own engineering capabilities. So as an owner, you can furnish a pretty minimal amount of information and the contractor can furnish the rest. When you get into some very specific details, you may find those details vary from contractor to contractor as well.
The best reference that I have actually seen is "Steel Plate Engineering Data: Volume 1 & Volume 2" (actually in one volume), published by the Steel Plate Fabricators/ American Iron & Steel Institute. The version I have is badly dated. I see listed here a more recently revised version, but I haven't actually seen it, so I don't know how it differs from the one I have. At $75, it seems considerably overpriced to me. Anyway, listed here:
https://www.steeltank.com/Publications/Publication...
Go to Amazon.com, put "steel storage tank book", and it pulls up several promising titles. However, out of the list, there is only one I have actually perused, and it relates more to the regulatory end of tanks.
The Structural Engineering Handbook by Gaylord & Gaylord has some information on tank design and foundation design- I'm not sure if it's worthwhile to buy the book just for that, but if you have a copy available, look into it.
A quick rundown of how tanks are designed:
Flat bottom- is specified, not designed.
Shell- checked for hoop tension due to hydrostatic pressure by simple t=2.6HD/sE type formulas in the standards.
Also checked for blow-in using equations for maximum height of unstiffened shell, usually wouldn't control design on that size tank.
Roof plate- will actually be a low cone, never flat- use radial rafters designed as simply-supported beams. Tank codes give maximum rafter spacing. Friction with the roof may be used for lateral stability of the rafters, depending on the code used.
Center column designed as a pinned-pinned column, may include eccentric loading due to unbalanced snow or erection loading.
If the tank is anything but atmospheric, then some complications arise, refer to App. F of API-650.
Overturning of the tank due to wind varies depending on the design code used.
Seismic design is covered in the design codes- App. E of API-650.
Welding procedures are usually ASME procedures, but AWS can also be used. Actual procedures will vary depending on the contractor. Roofs and bottoms are generally lap-welded from the top-side only, shells are butt-welded.
If the tank is storing anything but water, you may need to look into using floating roofs or other emission control equipment, secondary containment, leak-detection, etc.
I'm not sure what you mean about "...also designing sheathing as membrane and not as a flexural item...". If you mean the roof plate, see the provisions in the standards that give maximum rafter spacing as a function of roof thickness, which is how bending or strength of a rafter-supported roof is considered.
