Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The forum looks great! You guys have done a fantastic job on arranging things there...Your site is very precise and fun to visit..."
Geography
KKerr23 (Mechanical)
28 Jun 12 10:45
I am trying to denote a cosmetic thread I included on a rod I want to thread but there does not seem to be a way to call the thread out in the drawing. SolidWorks says that it is done by going into Insert-Model Items-Cosmetic Thread but there seems to be no cosmetic thread option in model items. Would anyone know where this would be?
PatCouture (Mechanical)
28 Jun 12 11:55
I had this exact same problem and I never found a solution for it. The cosmetic thread for external thread is so badly implemented in the software that it's almost a shame.
Patrick
Jboggs (Mechanical)
28 Jun 12 12:04
Type it in.
JMirisola (Mechanical)
28 Jun 12 12:33
What version are you on? I'm on 2012 and did the following without a problem:
    Create a rod
    'Insert annotations->cosmetic thread', define threads.
    Save part
    Create drawing from part
    Ensure that 'Import Annotations' is selected under Options in the View Palette
    Drag View onto sheet.
The thread callout propagated automagically.
Jeff Mirisola
Director of Engineering
M9 Defense
My Blog
CorBlimeyLimey (Mechanical)
28 Jun 12 12:47
KKerr23,
Are you looking for a thread notation similar to the Hole Callout?
28 Jun 12 15:48
You are right Jeff most often it works automatically but if it doesn't work there doesn't seem to be a way of getting the callout back.
28 Jun 12 15:56
Pat, can you post an instance where it doesn't work?
28 Jun 12 16:03
I am using 2012... Yeah something similar to a hole callout but just to denote the thread type and length on a rod... I have had a couple instances where it would not call it out by simply right clicking the cosmetic thread and selecting insert callout. This usually happened with uncommon sized rods, more so with shorter than 1/4" rods and sizes that are used for hole sizes. I did find the easiest thing to do was just make a note with a leader to the threads with the type and size on it... just tedious I guess you can say
29 Jun 12 12:33
I ended up writing the threads manually in the dimension box because I didn't want to spend anymore time on this issue.
If I remember right the problems was related to the type of thread, If I use ANSI it doesn't show but with ISO if would work or something like that. I don't have much time right now to investigate any further.
Please forgive me for the french version!
Patrick
29 Jun 12 14:02
Works fine for me if I remove your views and re-insert.
29 Jun 12 14:33
Also works if I remove your thread and reapply.
29 Jun 12 15:13
Are you on SW 2010 SP5?
Can this problem has been corrected in newer version?
Patrick
29 Jun 12 15:37
I'm running SW12-SP4. I have no idea if that was a bug which has been fixed.
If you right-clcik on the dotted line in the side view, do you have a Insert Callout option?
29 Jun 12 15:50
When I open the drawing, the right-click Insert Callout option is not available.
If I then open the part model, enter Edit Feature mode for the cosmetic thread and then select the green check mark without changing a thing, the callout option becomes available in the drawing.
... so I'm guessing it was a bug which has been fixed between 'SW0-SP5 & SW12-SP4
3 Jul 12 7:51
Thanks for your time CBL
I don't have the Insert Callout option you're describing so I won't be surprised that it was a bug that's been corrected.
Patrick
RangerGirl (Mechanical)
3 Jul 12 10:23
I had a similar issue before, using custom cosmetic threads. I found that when I right clicked on the thread the "insert callout" would not show unless the type of thread was manually typed in as an annotation when creating the cosmetic thread. Not sure if this helps, but may add some insight for later.
Close Box
Join Eng-Tips® Today!
Join Us             Close
