Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I just wanted to say THANKS for the forum. The knowledge I gain from your site is invaluable..."
Geography
RAKM (Electrical)
28 Jun 12 3:18
Hi guys,
Good day! I have a few problem in my piping, I try so many ways to address the leak of the threaded connection of HDPE pipe but still the problem keep coming back. For the reference the connection is HDPE-SS fitting which is use for pressure monitoring and sampling point. I was thinking to use PVC adapter as my connector in between.
Thanks a lot
moltenmetal (Chemical)
29 Jun 12 14:04
It's hard to understand what you are asking and what your problem is.
Does your HDPE fitting have a female NPT port, which you are threading a stainless steel male NPT fitting into? If the connection is small (1/4" NPT) and that kind of joint is leaking, you need a better thread sealant rather than a different type of fitting. For plastic to metal joints, you need a flexible anaerobic pipethread sealant which is compatible with the plastic you're using. Tape type sealants are insufficiently flexible to handle the creep and thermal expansion/contraction which is inevitable in an HDPE to metal joint of this type.
If the thread is a male NPT on the end of a piece of HDPE pipe, you need to weld a lapjoint flange on there instead, and put your instrument connection on a blind flange.
Close Box
Join Eng-Tips® Today!
Join Us             Close
