API 6D vs 594 swing check valve
If manufacture the 42" 150lb swing check valve which (6D/594) standard is applicable ?
42" swing check valve Face to Face End to End dimensions is not defined directly in table .
Design : API 6D / 594 ?
Face to Face : By agreement
Wall thickness : ASME 16.34
Flange End : ASME B16.47 Series B
Test : API 598
Lever & Counterweight : BS1868
Is this applicable to purchase a correct valve ?
Test : API 598
RE: API 6D vs 594 swing check valve
